I have 15 appliances that are all running WD1600AAJS drives. For some reason, two of them MDL: WD1600AAJS-62B4A0 will not load and error out every time when loading Citrix’s Xenserver 5.5.0. Each of the drives / systems is identical except for these two hard drives. They appear to be newer by a couple days than the ones that work. Is there something that I can check with the firmware that will make them function like the other drives. I’m in a pinch and need to resolve this quickly so any help would be appreciated.
The failing drives are as follows:
Model - WDC WD1600AAJS-62B4A0
Firmware - 03.03A01
Manufacture date - 12-31-2009
The good drives are as follows:
Model - WDC WD1600AAJS-00L7A0
Firmware - 01.03E01
Manufacture date - 1-3-2010 / 12-27-2009 (may be more haven’t pulled each system apart)
