WD TV power adapter
I lost the power adapter for my WD TV Live.  Is there anywhere I can buy one from?   http://store.westerndigital.com/store/wdus/en_US/DisplayAccesoryProductDetailsPage/productID.108411200  is what I want but I would love recommendations for buying it cheaper than $15 + shipping.
Thanks!
I would recommend to contact WD to see if they can send you one.-
Most of the time they’ll only do that if the adapter died on you.  As long as you get one that has the same specs as the original, it should work for you.  I think there a knowledge base article that tells you which adapter you have and what the specs are on it.
