WD TV Mini Playback sudden stop problem
i bought recently a WD TV Mini and i got the following problem:
  • many times when i’m watching something it suddenly stops and goes back to the main menu! Then shows a message something “Please insert a USB device”.
But even with that message i’m able to use and browse the disk.
If i insist in playing what i was watching it doesn’t resume where it stopped (and this is also very annoying). And most of times it stops again but in a different point!
I need some feedback here to help me understand what kind of problem is this.
I use a 500GB USB 2.0 external HD from WD.
The WD TV Mini has the latest Firmware version available on WD Support site: 1.00.60
I used MediaInfo (as suggested in this forum) to identify the type of CODEC some videos use and all had the above problem.
VIDEO #1:
Format                           : AVI
Format/Info                      : Audio Video Interleave
Overall bit rate                 : 2 516 Kbps
Format                           : MPEG-4 Visual
Format profile                   : Simple@L1
Format settings, BVOP            : No
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : DIVX
Codec ID/Info                    : Project Mayo
Codec ID/Hint                    : DivX 4
Duration                         : 56mn 31s
Bit rate                         : 2 375 Kbps
Width                            : 720 pixels
Height                           : 480 pixels
Display aspect ratio             : 3:2
Frame rate                       : 29.970 fps
Standard                         : NTSC
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.229
Stream size                      : 960 MiB (94%)
Writing library                  : Lavc51.44.0
VIDEO #2:
Format                           : AVI
Overall bit rate                 : 1 336 Kbps
Format profile                   : Advanced Simple@L5
Format settings, BVOP            : Yes
Format settings, Matrix          : Default (MPEG)
Muxing mode                      : Packed bitstream
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 57mn 33s
Bit rate                         : 1 189 Kbps
Width                            : 624 pixels
Height                           : 352 pixels
Display aspect ratio             : 16:9
Frame rate                       : 23.976 fps
Color space                      : YUV
Bit depth                        : 8 bits
Bits/(Pixel*Frame)               : 0.226
Stream size                      : 490 MiB (89%)
Writing library                  : XviD 1.2.1 (UTC 2008-12-04)
VIDEO #3:
Format                           : AVI
Overall bit rate                 : 1 954 Kbps
Codec ID                         : XVID
Duration                         : 1h 1mn
Bit rate                         : 1 718 Kbps
Width                            : 640 pixels
Height                           : 360 pixels
Color space                      : YUV
Bit depth                        : 8 bits
Bits/(Pixel*Frame)               : 0.249
Stream size                      : 760 MiB (88%)
Writing library                  : XviD 1.1.2 (UTC 2006-11-01)
Can you help me with this?
I’m a WD customer for many years.
Thank you very much in advance.
I have the exact same problem.
I have to either reconnect the drive or power the unit off and back on to continue.
I found it generally happens in the first 5 min or so of playback and may do it 2 or 3 times until it starts playing without any problems.
