Hi!
I’ve installed my new wd tv live today, and assumed it was pretty easy
anyways. Ive set it up with a DWA140 wireless adapter, which works fine. Can use youtube … update firmware etc.
When ive shared some folders on my computer, which is connected to the wireless router, via cable, nothing appears via wdtvlive. It does find my “shared documents tho” … and the demo vids etc which is there by default … if i put anything else in the same folders it doesnt appear.
Should UPnP be enabled on my router? … doesnt seem to make any difference tho…
Tried various settings from guids, forums… nothing seems to work. Or is it just better to use TVersity … ?
What does work is TVersity , somehow
It can play off anything, except x.264 it seems. Why is that?
Need to convert it to something else (if so, how :) … or can it just be renamed to something else.
Might be me doing something wrong, but i cant find anymore options. Im pretty new to this, help is appriciated
