I can connect with wd sync on mac, but not on windows PC. I have tried 5 different PS’s.
I cannot get past 5th step of guide How To Configure WD Sync with a My Cloud
After filling email and password, I get signed in but no device can be found. How to fix this?
Hello, peintbols
Well, follow the steps mention on the link and follow the steps in order to fix the issue.
https://support.wdc.com/knowledgebase/answer.aspx?ID=17824
If the issue persists, I would recommend you to try contacting WD’s Technical Support about this for live assistance and troubleshooting
http://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support
