Here is the situation with my Sharespace.
- Drive #4 amber light on. Extended test using Lifeguard passes. Discovery shows “unassigned” and “failed”.
- Drive #3 amber light on. Smart test fails, Extended test passes. Discovery shows “assigned” and “failed”.
- Operating in “degraded” mode.
- Red light flashing.
- I have 2.5 GB of data on the drive which is still accessible.
What is going on?
Hi royadavis,
You should try contacting WD’s Technical Support about this for live assistance and troubleshooting
http://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support
Create a Support Case
Create a support case with our world-class service and support team.
