WD Red Pro better UER rating than Se?
I’d like to know why the WD Red Pro drives have a better ‘Non-recoverable read errors per bits read’ rating than the Se drives given that the Se drives are more expensive and intended for datacentre use?
Red Pro: <1 in 10^15  ( http://www.wdc.com/wdproducts/library/SpecSheet/ENG/2879-800022.pdf))
Se: < 10 in 10^15 ( equal to <1 in 10^14)  ( http://www.wdc.com/wdproducts/library/SpecSheet/ENG/2879-771475.pdf))
Welcome to the Community.
This information is best explained by a WD Support Representative. You can do so either by phone or email.
Support by Country
Hi AndreasKa,
The WD Red Pro and WD Se should have the same URE, it looks like there may be an error in the documentation. I have forwarded this over internally to have the docs reviewed.
Thanks for the reply.
So to be clear, the URE for both these drives is 1 in 10^15?
For the most part, yes. I believe that it will be listed as <1 in 10^14, but that is the same as the WD Se at <10 in 10^15.
