Wd RED 6TB firmware errors?
hi
i recently discovered that some people are complaining about the new wd red 6TB and its firmware error,
do you know, if this firmware is still buggy, or if the new lines are errorfree?
today i bought one WD RED 6TB at my local dealer in town (i didnt buy online as precaution), and i got errors on first format under osx 10.9.4: “cannot write on the last block on this disc” (harddisc-toolkit).
i give it back tomorrow, and try a new one, will report if it works!
thanks
Hopefully the replacement drive will not show the same behavior.
Regards,
