WD MY passport Ultra is not detected, when i connect through USB, i only hear a beep.
data was cleaned up using the Blancco data removal software and since then the device is not detectable.
Hi Kiranrd7,
You should diagnose the My Passport Ultra using WD Drive Utilities on your computer and erase the drive to use further if detects.
