I am trying to connect my WD my passport 1TB drive to computer. The good part is that the drive is getting recognised but within few seconds it should following error message:
- Have you encountered similar issue?
- How to fix this?
Any help will be much appreciated!
P.S.: Just wanted to let veryone know that I have tried following without any success
Tried many things ::
- Disabled the shutoff settings on the USB menu - inside the Power settings ( which you find inside the control panel settings) → Same Error
- Changed a New USB 3.0 cable to try if thats the issue → Same Error
- Tried different ports-> 2.0 , 3.0 – the issues is the same on all . Also tried it on a different PC and different Windows Operating System → Same Error
