WD My Book Will Not Unlock Please Help
ok so I bought a WD My book from a friend of mine and I have been going thru **bleep** trying to get it to open , I have been dealing with WD support for 2 weeks and they have done nothing but send me to post on here that i have already read and ask me to explain the same thing over and over again… so I have gave up on getting the issue resoved by customer support with that said I figured maybe someone here might be of real help… so let me explain I have spent hours reading anything i could find and have downloaded all the drivers and software I can find and tried everything and nothing is working…
details: its a WD My Book (WDBACW0040HBK)
I use a Macbook Pro 2.66ghz 6gb ram 128gb SSD running OS X 10.10
also have a 2.87ghz 6gb ram 500gb HD windows 8.1 pc as well
images of everything it allows me to see :
also let me add that ,the same friend gave me another hd (2tb my passport) last night that loaded up perfectly . plugged in usb and unlock window popped right up instantly but still nothing for the my book
Hi there,
Have you tried to unlock the drive on a different computer, this is not normal. You can also try to re install the drive security to see if you can unlock the drive.
