As you can see in video, my WD Book Studio 2 has an unusual led blinking. I do not know if this is a led problem (maybe the led is near to get damage) or if is something bigger (pcb problem)…?
Do you have any idea.? Thanks.!
Testing the unit with a diagnostic software will be your best bet to verify if the drives are also failing.
Try the information on the links bellow:
How to test a drive for problems using Data Lifeguard Diagnostics for Windows
http://wdc.custhelp.com/app/answers/detail/a_id/940
How to test a drive for defects or problems on a Mac
