Please I’d appreciate for your help about my WD My Book Studio Edition II 2 TB So,
I tried once more a time to start it again So I can see the partition in my computer after a long load time but the same the partition was asks for format and I don’t and now not asking and the drive seems to be no data inside and no file system and can’t detect the HDD spaces only if I’m in Disk management and it’s said healthy OK but no file system ?
Note : As you know, the indicator bright in the foreground looks like the letter I become light in the form of flash from the highest index to bottom except the center on the continuation thereof and useless left with a lot of time hoping to work again. So is there any difference
and the partition found in my computer but it’s like RAW without file system & Healthy in disk managment, WD Drive manager and When try to use Raid manager it’s said Device not found .
All that happened in my sleeping time and When waked up find that problem So don’t know what’s happened But I’m sure u will know more than me. much appreciated
This one is kind of difficult. However, download Recuva or Photorec perhaps you will be able to recover some information with this application is free.
Guys any programs cant detect the size of disk or any info only the name WD my book and the size 0 kb and only detect after the long time loading the device in Disk management Only with the capacity size and the partition icon visible in my computer but I can’t format or do anything to access the Device So any help if I take them out and connect them inside the PC with sata cables would be ok or no ? I can’t fix the device with any softwares on internet I used them all who’s showed in Google but no news still no access So any help to format ? or must take them out and connect them inside PC with Sata cables ?
