WD My Book Problem
Hi, my name is tony and i have a WD My book 2TB
When i try to copy something it says :
Could not find this item.
This is no longer located in computer. Verify the item’s location and try again
My Book
Space free : 1.23 TB
Total size : 1.81 TB
Yesterday it was reading with 3 mb… and i reinstalled his apps and now is reading with 25 mb…
Please, HELP.
Does this happen with multiple files or just one folder?
Can you try creating a folder on the drive and see if it gives you an error message?
I can create folders, and today i see i can’t delete a folder from the driver it says : You can’t delete the folder. The folder is not empty.
and a folder can be deleted  a folder no… i have 15 folders… 7 can be deleted , but 8 can’t be.
This sounds like corrupted files.
Backup as much data as possible and reformat the drive.
After that run a test with Data Lifeguard Diagnostics.
How to test a drive for problems using Data Lifeguard Diagnostics for Windows
http://wdc.custhelp.com/app/answers/detail/a_id/940
