Hi, I have WD my book live and today it’s reporting solid red light after turning on and after some time it goes off, mybook live is appearing on network drive list but unable to access any folder, my book live web interface is accessible, I have tried power reset and have changed ethernet cable, also have changed port on router but unfortunately no joy.
I have tried following steps to recover any filesystem issues but still no luck
any help would be highly appreciated
fsck /dev/sda4
MyBookLive:~# fsck /dev/sda4
fsck from util-linux-ng 2.17.2
e2fsck 1.41.12 (17-May-2010)
/dev/sda4 is mounted.
WARNING!!! The filesystem is mounted. If you continue you WILL
cause SEVERE filesystem damage.
Do you really want to continue (y/n)? yes
/dev/sda4: recovering journal
/dev/sda4 has been mounted 80 times without being checked, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Inode 16817218 ref count is 1, should be 2. Fix? yes
Unattached zero-length inode 29304713. Clear? yes
Pass 5: Checking group summary information
Block bitmap differences: +(3622534–3622535) -16841531 -16847919 -17179428 +17277654 +17659541 -17659542 +(17916342–17916343) +17916742 -30215552 -30215670
Fix? yes
Free blocks count wrong for group #257 (0, counted=2).
Fix? yes
Free blocks count wrong for group #262 (2, counted=3).
Fix? yes
Free blocks count wrong for group #263 (5, counted=3).
Fix? yes
Free blocks count wrong for group #269 (3, counted=2).
Fix? yes
Free blocks count wrong for group #273 (83, counted=81).
Fix? yes
Free blocks count wrong (9670, counted=9668).
Fix? yes
Inode bitmap differences: +16830093 +16830130
Fix? yes
Free inodes count wrong for group #257 (12110, counted=12109).
Fix? yes
Free inodes count wrong for group #448 (404, counted=403).
Fix? yes
Free inodes count wrong (30020737, counted=30020735).
Fix? yes
