I recently picked up a WD Live TV Plus. It’s worked great so far and I’ve connected it to a variety of external hard drives thus far.
The problem arose when I tried to connect it to my external RAID enclosure with a 3TB RAID 1 Array.
I made the sure the firmware was upgraded and everything seemed to up to par yet it still will not recognize the enclosure when connected.
The enclosure has a LCD display on the front which registers any time a connection is made and it does say “USB Connected” when I plug it into the WD Live box but the box does not recognize the connection.
Any advice or tips?
For reference purposes. The enclosure is a SansDigital TowerSTOR TS2CT with two 3TB Seagate Barracuda XT drives.
Thanks in advance!
Regards,
Flawless
