WD live tv hub and wireless usb
#1
Hi
does dwa-140 dlink go with WD live tv hub?
#2
Yes, as long as it is the correct version.
D-Link Rangebooster N USB Adapter DWA-140 V1.30
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=5688
#3
is it only that version or version above allso?
#4
Thats the only one that WD have ‘tested’. Others may work but it all depends on the internal chipset of the adaptor.
