Wd live hub technical problem:it doesn't turn on
#1
Hello  to all of you. I would appreciate any help on a problem I have with my WD TV LIVE HUB.it had been working properly until recently. Now it turns o for a few seconds ( I can hear e sound and see the light) but then the light blinks for a few seconds and turns off itself. I checked the cables, I pressed the reset button, but nothing. I don’t know much on the subject so as I said I would appreciate your opinions on the resolution of this problem before taking it to the store. Thank you
#2
It’s a known hardware issue affecting the POWER BUTTON on some units.   Exchange it for a new one.
http://community.wdc.com/t5/General-Discussions/Help-Hub-powers-up-WD-light-flashes-then-powers-itself-off/m-p/104158/highlight/true#M2590
