Hi all, My My book is the legacy one with the green circle. It plugs into the PC via USB. I started getting read failures. Tested it on another PC and it behaved. Now the USB Connection continuously connections and disconnects and then eventually stops. Windows says that the USB device is not recognized sometimes and when testing on my other PC the same issues show up. I am not sure that this means the drives are bad. At the very least it means the USB connection device inside the external drive has gone bad. BTW, sometimes the connection stays on long enough to where I can see all my data on the drives. But othertimes I see nothing and sometimes I am told that the drive is loaded with bad sectors. Data recovery services as a last resort, what are my options
Windows XP all the latest updates
Asus P5Q MB
3gig ram
