WD 2 TB Purple does not power up
I recently purchased a 2TB Purple HDD (model WD20PURZ, date: 13 May 2018), and when I connect it to the DVR it would say that it does not detect it ( 12V/2.5A).
I assumed either the DVR is faulty or the drive was not getting enough power.
I read online that it could be that the amperage was low, so I purchased a power-supply 12V/5A
But the drive does not spin up!
Do you guys think drive is faulty.
PS: hello all, first post in the forum.
Hi charm_quark,
You can refer the link mentioned below and check the power management column to find out the average power requirements under different operations on the drive.
https://www.wd.com/content/dam/wdc/website/downloadable_assets/eng/spec_data_sheet/2879-800012.pdf
I checked that it has enough power, I borrowed a 2 Tb from a friend ( a Toshiba) and works fine. I guess the new drive is dead then :frowning:
