I have been using the same 3GB USB drive to transfer files from my laptop to my WD TV Live Hub since I purchased it a couple of months ago.
I was formatting it in Windows to completely remove the old files to make room for new files.
I started to format it on my Linux (uBuntu) machine and the WD TV no longer recognizes the drive.
Can you tell me why this is happening?
Thanks,
Rich
