Urgent Help!
Hi there all you technologically capable people!!
I obviously, have a problemo!
Well!!!
Long story short I had all my files backed up from my computer on my Passport Essential, then comp crashed had to get a new hardrive, plugged in my Passport for file retrieving and there is NO BACKED UP VOLUMES in the retrieve tab!!!
I am having a bit of a panic…
Is there a way I can get to the files and restore them through the My Computer Folder??
Thanks so much!!! :slight_smile:
Yes. You can go into the backup folder and retrieve the backed up files. It will be named Smartware if you have and older Smartware version or smartware_stor if you have a newer version.
You may have to do a new backup see post http://community.wdc.com/t5/My-Book-for-PC/data-restore/m-p/161586/highlight/true#M5703
Joe
