“Uncorrectable errors count” and showing HDD fineness as zero what cause will be the issue. for this.
I have check and run with Speed fan, is that effect for the sudden HDD failure.??
Chamila
Chamila
Hi cham094,
https://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support.
LBA -0 PROBLEM SA BAD YOU NEED DATA ? NEED HDD? NEED DATA FIST RECOVERY AFTER REPLACE WD HDD
WD SERVICE CENTER ALL WORD CHECK WEBSIT …NEED SERVICE CENTER LOCATION INDIA :Click
