Spot on,ok so now the device correctly reports current firmware as: 2.8.13 (I didn’t end up going back yet another version).
Note the rollback did fix the link issue from the WD Page to the Twonky page, now correctly goes to http://name:9000 as it should.
BUT I still have the issues with Twonky not indexing any files on the Device… I am stuffed I have spent around 4 hours today and still haven’t found an answer.
So my issue remains un resolved… what I see below is the status for Twonky.
5.1.9Cache memory:552 KB
Last database change:In Progress
[+ /mediaitems/Local/WDTVLiveHub]/_Movies/_HI DEF Movies/NAME REMOVED BY ME
Music tracks:0
Photos:0
Videos:0
License information:The Server is registered.
Server uptime:0 days, 0:07:38 hours
Server built date:Sep 27 2010
Server restart pending:no
Network Interfaces:127.0.0.1 192.168.xx.xx (Again IP removed by me)
I have gone in and run the restart, rescan and rebuild with no success, still shows 0 indexed files.
Reading online forums the Twonky version has remaind the same through out all firmware updates from WD, I see little point in going back to older firmware to test further.
Does anyone use Twonky on the WD Live TV Hub under 3.3.19 and does it work?
Perhaps a better question is:
Who uses twonky on the WD TV Live Hub and can see indexed videos, music and photos - what firmware are you running?
Anyone have any other steps I could take?
(I seem to recall reading about a guy who deleted or cleared two files over SSH on his WD device - of course I can’t find the details about that now… grrrr).
What steps should I now take?
