I’ve been using a Western Digital My Book Essential Edition WD5000C032-002 500Go USB 2.0 for a couple of years to backup another external hard drive I have. I use SuperDuper on a MacBook Pro running OSX 10.8.5 to do nightly, incremental backups.
Lately, I decided that the drive would served another purpose and backup another drive. So I started a new backup. For the first pass, before the incremental backup can start, a full clone must be produced. I noticed that the writing speed of the disk was very slow (see below).
I did speed tests with Blackmagic Disk Speed Test: it’s around 1 or 2 MB/s. I did my tests using two different USB cables (3-4 feet). Those USB cables were connected to my MacBook Pro. I did “Verify” and “Repair” the disk using DiskUtility: no error came up, the disk seems to be in order. I nonetheless use DiskWarrior to rebuild the directory anew. It didn’t fix the speed issue. I also did reboot the computer during the test, plug and unplug the USB cables and unplugged/replugged the HD power supply.
Is the disk failing (I’ll buy another one) or is there other tests to run?
Thanks.
