I’ve been trying to rebuild Transmission for FW 4 based on WD’s documentation for the past 2 hours but no luck so far.
I have 64 bit ubuntu running in a VM. I installed the packages required as per WD document, namely "qemu-user-static"and “binfmt-support”
Now im no Linux expert at all…I could be doing this wrong. but when i try to rebuild transmission, it starts wroking on it for like 5 mins and then eventually fails:
I run the following command at “/gpl-source-sequoia-04.00.00-607/packages/build_tools/debian”
./build-armhf-package.sh --pagesize=64k transmission wheezy
The entire build log is over a thousand linesk. I’ll put it on drop box soon and paste link here
EDIT: Log file for the build process
