Time Machine error on M1 Mac using Sandisk Extreme Pro SSD
I’m using a Macbook Pro M1 on Monterrey. Time machine wont back up and I get this repeated error: " Time Machine did not back up because the computer was running on battery power. Connect your Mac to a power source while your backup disk is available."
  • I am connected to power
  • I’ve connected the drive and power directly to the laptop without any dongles
  • Ive turned off screensaver, hard drive does not spin down, disable lock screen
  • i’ve deleted all snapshots from my mac
I’m at a loss why this backup never completes; it goes to about 30% or so and fails. Has anyone figured this one out? thank you
Hi @aluceno,
Have you opened a Support Case? If not opened, for more information, please contact the SD Technical Support team for best assistance and troubleshooting:
