As to the problem removing the drive, I seem to hvae fixed it.
I was finally able to do a chkdsk by dismounting the drive when it asked me to (per suggestion in another forum), and chkdsk ran ok, fixed some errors, and the missing folder is back and I was just able to remove the drive properly…
I havent checked about the problem with xp, but I am hopeful.
thanks/excuses to anyone who spent time reading this…
ok. here goes.
lots of info, but no clue what it all means.
using wd my passport on vista and xp
on wd my passport 500Gig
It started with a corrupted folder.
I run testdisk, i can see the data, i back it up.
when i try to delete the recovered data from my hard drive (not the removable drive)
since i dont need it anymore
it tells me it is all shared…I have to remove sharing to delete it. Why???
Anyhow, I try to use the drive on my xp
I get blue screen of death
problem with ntfs.sys when i try to load the drive
sorry i dont have the exact message this moment
meanwhile, vista loads the drive, but refuses to remove the drive.
program is still using it messge
I try to run chkdsk from drive properties tools
It tries to boot from the drive, instead of my hard drive
but tells me that bootmgr is missing
On reboot i override to boot from hard drive.
it does not do the chkdsk
I run chkdsk from a command console
it gives me
The type of the file system is NTFS.
Volume label is My Passport.
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)…
0 percent complete. (0 of 234928 file records processed)
File record segment 1225 is corrupt.
File record segment 1335 is corrupt.
1 percent complete. (23493 of 234928 file records processed)
2 percent complete. (46986 of 234928 file records processed)
Attribute record (128, “”) from file record segment 64576
is corrupt.
3 percent complete. (70479 of 234928 file records processed)
Truncating badly linked attribute records
from file record segment 71330.
4 percent complete. (93972 of 234928 file records processed)
from file record segment 94567.
5 percent complete. (117464 of 234928 file records processed)
5 percent complete. (138369 of 234928 file records processed)
6 percent complete. (140957 of 234928 file records processed)
Attribute record (48, “”) from file record segment 152362
is corrupt.
7 percent complete. (164450 of 234928 file records processed)
8 percent complete. (187943 of 234928 file records processed)
Attribute record (48, “”) from file record segment 207094
is corrupt.
9 percent complete. (211436 of 234928 file records processed)
234928 file records processed.
File verification completed.
File record segment 36035 is an orphan.
10 large file records processed.
File record segment 127910 is an orphan.
Errors found. CHKDSK cannot continue in read-only mode.
I try wiith f switch
it says I have to dismount. I am not sure if this is safe, so I say no.
it asks to do on reboot…back to square one.
In the event explorer, I see a message
Log Name: System
Source: Service Control Manager
Date: 9/11/12 4:21:12 AM
Event ID: 7026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: neco2-PC
Description:
The following boot-start or system-start driver(s) failed to load:
i8042prt
Event Xml:
7026
0
2
0
0
0x80000000000000
39369
System
neco2-PC
i8042prt
I run process explorer and run file handle search
it tells me
svchost.exe is using it with desktop window manager as a sub thread
in two places
G:$Extend$ObjId
and
G:\System Volume Information\tracking.log
I try closing handles, they reappear
I should say this was happening.
Currently process explorer is finding no handles for my drive,
but still no luck removing.
So I have no clue what process it is that is hanging things up.
I go to file explorer as administratorand I enable system files
but it wont give me access to the G:\System Volume Information\ folder
and I dont understand the first.
I also get a handle from another program, object dock, referencing a recycle bin on the drive
I close the program, and the handle disappears,
but
I see the recycle bin in my file explorer. I check my recycle bin properties in windows, and yes it it there.
I check do not remove to recycl bin, thinking that will help, but no luck.
Should I delete the recycle bin? Can I delete it? How do I delete it?
in administrative tools event viewer I get messages
about system preventing me from unload drive
Log Name: System
Source: Ntfs
Date: 9/11/12 2:48:36 AM
Event ID: 137
Task Category: (2)
Level: Error
Keywords: Classic
User: N/A
Computer: neco2-PC
Description:
The default transaction resource manager on volume G: encountered a non-retryable error and could not start. The data contains the error code.
Event Xml:
137
2
2
0x80000000000000
38857
System
neco2-PC
G:
1C0004000200300002000000890004C000000000020100C000000000000000000000000000000000020100C0
Log Name: System
Source: Ntfs
Event ID: 55
Task Category: (2)
Level: Error
Keywords: Classic
User: N/A
Computer: neco2-PC
Description:
The file system structure on the disk is corrupt and unusable. Please run the chkdsk utility on the volume My Passport.
Event Xml:
55
2
2
0x80000000000000
38856
System
neco2-PC
My Passport
00000C000200380002000000370004C000000000020100C000000000000000000000000000000000CF0503002200000000000100
Log Name: System
Source: Ntfs
Event ID: 131
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Computer: neco2-PC
Description:
The file system structure on volume G: cannot be corrected.
Please run the chkdsk utility on the volume G:.
Event Xml:
131
0
2
0
0
0x8000000000000000
38855
System
neco2-PC
2
G:
25008: Start repair on 09/11/2012 at 02:48:36:372
27184: The unnamed data attribute in file 0x1000000000022 is missing.
25007: Adding attribute of type code 0x80 for file record 0x1000000000022.
25009: End repair on 09/11/2012 at 02:48:36:372
136
2200000000000100CF05030004000080020100C000000000000000000000000000000000000000000000000000000000000000000400000006000000060000000000000000000000000000000F0000000A00000009000000000000000000000000000000000000000000000000000000000000000500000000000000000000000000000000000000
Log Name: System
Source: Ntfs
Event ID: 55
Task Category: (2)
Level: Error
Keywords: Classic
User: N/A
Computer: neco2-PC
Description:
The file system structure on the disk is corrupt and unusable. Please run the chkdsk utility on the volume G:.
Event Xml:
55
2
2
0x80000000000000
38854
System
neco2-PC
G:
1C000C000200380002000000370004C000000000020100C018000000000000000000000000000000CF0503002200000000000100
I tried disabling the virus checker, but it still wont remove it…
If I try to delete the corrupt folder, it tells me the folder is no empty, and refuses to do so.
What do I do??
ps
I dont know if it is related,
I was getting a message to load drive each time i put the drive in, as I know it should, with 3 options. I was just cancelling each time, as per manual, but one time I clicked stop asking, and it stopped asking. but then
I started having problem below, so i deleted the driver, and the message reappears as before, as it should…
