Hi, I hooked up my new WD TV Live to my Advance Acoustic amp using a 2RCA male to 3.5mm male. I had horrible audio distortion without even playing anything. I tried using the cable that came with the box and had the same result. I even tried the WD TV live with my 2.1 computer speakers and had the same audio distortion. I saw some older threads that audio distortion has been an issue with the WD TV Live. I’m facing this issue only with the composite output, the HDMI is working perfectly fine - I’m currently routing the audio in through my TV but don’t want to continue doing this. I’m running firmware version number 1.10.13
Any fixes/ideas what I can do to sort this out? Is this a hardware issue and should I ask for an exchange? Please help! Thanks.
