What is the cheapest way to get surround sound for my WDTV Live. I do not want to spend a lot. Also it should be DD & DTS. No need for HD audio now. Just want to get real surround before HD audio equips go cheap. Do not suggest z5500 or Pro Logic.
Regards,
Prakash.
Um, I suggest a good AV receiver.
Any of the lower end 5.1 Yamaha models are a good choice (you can actually get a nice one for less than $200). Now, this *will* require speakers, but once again Yamaha makes a nice 5.1 speaker package that’s very reasonable if you don’t have the necessary ones already.
