Hi All
I’ve got an mp4 file that has a separate subtitle track, how can I set to use the subtitles, they are an srt file, I tried putting them into the same folder, then transferred them to the drive (WD Play 1TB) , but when I play the film and press the option button it says there are no subtitles.
I have also tried using a program called Xvid4PSP and soft coding them to the MP4 file but that doesn’t work either, although when I play both files on the PC using vlc the subs work fine!
Am I doing anything wrong or will it just not play subs unless they are hardcoded on??
Thanks Pete
P.S i forgot to say that if i convert the film to a dvd structure iso file inc the subtitles then i transfer that over and play the subtitles show up no problem, but this is a lot of work to do, just hoping there is a much easier option?
