I have been using WD TV Live Streaming (current firmware 1.12.14) for a while with two HD attached.
The WD My Book Essential 2TB USB3 and HGST (own by WD) 4TB Touro Desk Pro USB3 HD.
This worked fine until I decided to disconnect 4 TB HD in order to store more files directly from my Win 8 PC.
Which I did without any issues, but now the WD TV Live will no longer recognize this drive at all.
I try to reset the WD TV Live, I even downgraded the firmware to 1.10.13 (now is again 1.12.14) but the same problem exists.
Even when the only connected HD is the 4 TB it is no longer recognized by WD TV Live.
Any idea what is the problem and how to resolve it?
Instead of this 4 TB I now connected 2x2TB WD HDs – so now I have 3 of these connected and this works fine.
I noticed that on WD official list of the supported HDs are only HDs up to 2 TB.
Are HDs over 2 TB supported?
In my case 4TB unit worked fine under 1.12.14 until now.
The 4 TB Hitachi works fine when attached to any PC – tested fine as well.
UPDATE
While trying to resolve this issue, I also experienced similar issue later on with one of the WD 2TB HDs.
It looks to me that problem is due a lack of the Safely Remove routine that disappeared from the firmware some time ago.
Right now God only knows how to safely remove the HD and this is a serious problem.
