I have a problem. I set resolution to 1080p and i can normally play videos. when I start the player searches for the optimal resolution and the start was delayed for more than a minute. Is this normal? I can avoid scanning??
It’s not searching. It’s booting.
Is it normal? ¿How much time it does take to start?
About a minute, if I recall, from power off.
Just a few seconds if coming out of standby.
If it’s starting after a full power-down (holding down POWER key for several seconds), it has to do a full boot. It starts at 720p for the initial screen, then resets the video to what your settings are.
Is not this too slow startup? Also I have the old version (gen2) and it starts quick.
IIRC, it actually about as fast as the Live under the same conditions…
