root@Unknow:/test# sshfs 192.168.1.50:/DataVolume/shares /test
root@192.168.1.50's password:
root@Unknow:/test# cd ..
root@Unknow:/# cd test
root@Unknow:/test# ls
Documentales Ingles OSBackup Public Torrenting VideoClips
Fotos Musica Peliculas Series
root@Unknow:/# fusermount -u test
root@Unknow:/# sshfs MyNOIPADDRESS:3022/DataVolume/shares /test
The authenticity of host MyNOIPADDRESS(2.139.14.171)' can't be established.
RSA key fingerprint is 10:4c:eb:8b:d4:8c:bd:6c:42:d7:6f:a8:b0:a0:34:56.
Are you sure you want to continue connecting (yes/no)? yes
root@MyNOIPADDRESS's password:
read: Connection reset by peer
root@Unknow:/#
Access and mount works perfectly on LAN as show.
Port is forwarded 3022-22 and it works for WAN in SSH from terminal or putty but i have no success from WAN in SSHFS using my noip address.
Sure i’m missing something obvious about command construction.
