I bought a WD Livewire last week and hooked it up on Saturday. My DSL modem and one Livewire unit are at one end of the house and the other livewire unit was about 80 feet away in another room. The Livewire utility showed the connection for the remote until was at 5-6 mbps and when I hooked up a laptop at the remote end Speed test only got about 120k. I moved the remote end unit to an outlet in the same room as the primary and the Livewire utility showed 147mbps, so I believe it was set up correctly. However, plugging it in one room away the Livewire utility showed speeds of only 9-10 mbps.
Is there anything I can do to improve the speed to other rooms or is this just not going to work with my wiring?
