You mentioned above that you tried changing the shared folder name. Did you actually change the SHARE NAME, or the FOLDER NAME?
They aren’t necessarily the same.
One way to check is to open a CMD window and execute the command
net view \pcname
(where pcname is the network name of your pc that’s sharing the folders.)
Cut * paste the output of that command.
I will cut and paste the results when I am home this afternoon
I have tried both, changing the actual folder name and the shared folder name.
Most of the time these two are the same in my case.
Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Vin>net view\Vi-PC The syntax of this command is:
NET [ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP | HELPMSG | LOCALGROUP | PAUSE | SESSION | SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW]
This is what I got when executed the command
I am not sure if this is correct
You forgot the space between “view” and “\Vi-PC”.
my Bad
here are the results
C:\Users\Vin>net view [\Vi-Pc](file://%5C%5CVi-Pc) Shared resources at [\Vinod-Pc](file://%5C%5CVinod-Pc)
Share name Type Used as Comment
HD Disk Y:
HD Movies
Disk HP LaserJet P1005 Print HP LaserJet P1005
Movies Disk Z: The command completed successfully.
Thanks for your help
I currently noticed the same issue with my folders.
Animation
Animation Motion Comics
Animation Disney
Music
Musical Movies
for some reason its almost like the wdtv smp is taking the first few characters of the folder and thinks that the folders are the same. Anyone found a solution for this? All my media is on a nas drive however as some of my media is from an external esata drive on the nas and the rest on on the nas raid it is easier if i can use media library to show all folders in one directory instead of through subfolders. There is some basic features which wd keep leaving out which constanly keeps reminding me to upgrade it. Also no gigabit lan so and small cache buffer so isos stutter. Just waiting for a sigma media player to comeout which can handle 3d isos. have you managed to resolve the problem on this
thanks
I wish I could help, I never got this fixed… I got a lot of suggestions from fellow members but no luck.
My problem was these 2 folders:
HD Movies
HD
I am using Plex server now, since I do not have a NAS. I just turn my computer on whenever I am ready to watch movies or listen to my musics
The WD SMP picks up the server nicely without any issues.
Plex is the way to go if you don’t have a NAS
Also note that my files sharing structure is still the same where my movies resides in 3 folders
I hope we can get this fixed somehow
