I have version 1.6.0 of the Western Digital Smartware installed on a 64bit version Windows 7 with service pack 1.
Everything installed correctly and appears to be working, however once I started my backup it just sits there and won’t backup anything like it’s waiting for the system to be idle. I remember a “Backup Speed” setting under the software settings category used to be there, however they aren’t there now. I even checked the help tab for the software which states:
"Pausing backups until your computer is idle
A large backup can take a lot of time, and can consume a lot of your system processing resources. The WD SmartWare software works in the background using minimal computer resources while you are working on your computer. If you want to pause all backup activity until your computer is idle:
- On the Software Settings screen, click Backup Speed to display the Reduce Backup Speed dialog.
- Select or clear the Run backup when computer is idle check box to enable or disable the Backup Speed option"
So, how do I change the backup speed and uncheck the “wait for system idle” settings if the settings aren’t in the software?
