Having an issue with a WD Sharespace basically the unit was dying a slow death…So i ended up formatting all 4 disks thinking i could pop them in an it should re-install the firmware etc…That was my bad left it sitting for a day the firmware re-install didn’t work tried the following so far.
Im sorry but if you formatted all 4 drives of the Sharespace that means the Operating System was deleted. Unfortunately this is not recoverable and I recommend that you get the Sharespace replaced.
You may contact Western Digital for assistance in replacing your drive.
I don’t know if it will help with all drives wiped, but with another WDSS available you might make it work.
PLEASE NOTE: Read the entire article before you try anything. The author went through a lot to succeed, and there are significant warnings. The most important, in my book, is that you should image your drives and work with the copies. This will give you an extra level of safety.
There may be other such accounts. This is the first one I found which seems to apply.
EDIT: There is substantial information on debricking a WDSS in the posts from this search-
