The cord for my power adapter broke…I can’t seem to find anywhere (via online searching) to get a replacement one for my Elements 1TB hard drive. Model - WDBAAU0010HBK-01
It must be suitable for Australian use…the only ones I can find are for the northern hemisphere.
If you can’t get a replacement from WD, then you should be able to obtain a compatible adapter from places like **bleep** Smith Electronics, Jaycar, Altronics.
