need replacement adapter for Elements External USB Drive 250 GB WD 2500C035 - do not know how or where to find; thanks in advance
photo enclosed of the unit; looking for adapter cord
thank you!
thank you!
Hi metro22,
https://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support.
thank you again
i found one on amazon
Which one did you find? Can you send me a link please?
