Remote replacement in dubai
I am looking to buy a remote for my WD TV product code WDTV001RNN, I have tried a lot to locate WD in Dubai – UAE, but not a single number on the web is active.
Pl. advice details for your service center or a store where I can buy this remote.
Best Regards,
MJ.
Are any of these distributors contactable ?
http://www.wdc.com/en/buy/distributors/default.aspx?dname=®ion=6&subrgn=239#sr239
Sorta off-topic but … the WDTV Live Hub & SMP Remote control will work with older WDTV Live & Plus (and vice-versa)
So, it’s an option if you can’t get the little mini remote.
