Is there remote application to PC or Iphone, where you can see same screen as is on TV. WD Discovery remote is useless for me. It’s only picture of your physical remote control. You can press buttons but you don’t see what happens if your TV isn’t on. This is same thing, if you use remote desktop connection to PC and only thing you see on your own screen is picture of keyboard.
There is no way to view the hub interface on anything else than a tv unless it is directly connected to a video output on the hub!
If you want to play media files from the hub or any other media server on your Iphone or send media to other devices using your Iphone as a browser, there are some alternatives:
http://www.zappo.tv/ (Free, but limited)
http://www.plugplayer.com/ (Cost a little, but is awesome)
