I have setup MyCloud access on a MBL with different users, which works perfectly. However, when I use the network share options, I run into a couple of issues…
I have ‘Read Only’ access to every file. When I open existing files, I get a login/password screen from [http://mybooklive.device******wd2go.com…,](http://mybooklive.device ****** wd2go.com…,) which does not accept my MBL credentials (not even the build-in admin). Looks like he lost his credentials from that point on… Funny thing is that I can create, modify and delete every folder ánd notepad .txt files, also existing ones.
On newly created shares, which I connect to on the same way with Remote Access as any other, I can open and edit new files, but when I want to save them, I get a ‘Document could not be saved’ error. This is only the case for Word and Excel documents. Ánd also here I have full rights on folders and notepad .txt files, but not with .docx/xlsx files…
Keep in mind, this ONLY occures in the “MyCloud network share environment”. When I use the MBL shares on the internal network, all permissions work flawless.
Do I have to enable FTP? Hardly seems the case, because I connect on ports 80/443 and not on FTP ports. Seems like the temp files from Microsoft Office get in the way with the permissions…
Maybe you guys can shine some light on it!
