Hello
I think this is important.
I decided to connect my WD cloud to my computer through USP cable so I connected it to the power first then USB , 2 minutes later I disconnect it fom the power first ( the power light was still on ),then I disconnect the USB cable after 5 secounds.
When I tried to connect again it starts to give the solid red light and offcourse it is not responding.
I tried to reset (soft & hard ) but still the same problem…
I don’t know if I did anything wrong by disconnecting the power before USB?!!!
if there’s any solution please let me know
note: My WD cloud was working fine for more than 4 months
