Greetings All,
So after my MyBook Live died I was able to swap it out for the MyBook Cloud which seems to be working 100% according to the dashboard status however the “red” led never stops flashing. It passes the diagnostic tests without a issue and according to the dashboard the temprature is okay however according to the report dump “smart_info” reports temprature at:
194 Temperature_Celsius 0x0022 106 093 000 Old_age Always - 44
Value is at 106 and RAW_Value is 44 so I am not sure which is the correct value to take read but there you go.
I have restarted the device and shut it down and started it up again but the “red” led carries on flashing. I have rebuilt the media database thinking that was the issue but it carries on flashing :/. The drive is on the latest firmware.
/BTW I say red in inverted comma’s because it looks more pink than red :P.
