Recover data from hard disk after failure - Red LED
ENGLISCH (Deutsch weiter unten):
I need your help. I no longer have access to my data, which became inaccessible after a hard drive failure.
General Info:
  • NAS System: WD My Cloud EX2 Ultra (purchased 2019).
  • Raid 1 (Both mirrored 1to1).
  • 2 x 6TB(5,94TB) WD Red
  • approx. 4.5TB Used
  • 2 Users
  • 1 Shared drive / share
  • 1 Private drive / share each
History:
  1. one LED has lit red
  2. harddisk (A) was faulty - DiskDrill shows ~2000 bad sectors
  3. the shares were gone
  4. tried to add the shares again
  5. ticket contact with WD
    5.1. recommendation of a new harddisk
  6. new “hard drive C” (WD RED 6 TB) was bought and installed
  7. raid was restored and all was well
  8. shortly after both LEDs were red and I couldn’t access anything (don’t understand why)
  9. harddisk B and C were not accessible anymore
  10. raid rebuilt harddisks (B and C) had to be formatted in the process
  11. contact with WD support unfortunately without success.
    11.1. data recovery or bad luck :frowning:
My current attempts:
  • Harddisk A (which was considered defective) connected to PC
  • With DiskDrill (bought) read out, after 16 hours ~1 million data (2.8TB) found
    • Unfortunately not the original filename
    • Unfortunately not the original path to be able to assign the data
  • Read out with Stellaris Data Recovery (bought), after 16 hours ~70k data (1 TB) found
    • Unfortunately not the original path to be able to match the data
  • With Recuva (trial version) no real success had
  • With dmde (purchased) had no real success
What can I do to get the data back?
  • Preferably with the original filename and file path.
My ideas:
  • Access the data with Linux? Unfortunately it fails because of the VirtualBox
    • Is it possible without a Recover-Tool?
    • With a Linux Recover tool
  • Try data recovery with other recovery tools
  • Go to data recovery professionals (depending on cost)
  • The data laboriously rename, sort and read out piece by piece by hand. Is unfortunately with 4.5 TB very laborious without file names and path and thousands of temp data
  • remove the currently installed hard disks (B and C) and also read them out with a Recover-Tool
    • So from 3(A, B and C) make 1 (D(factory new))
Additional info:
  • I bought a fourth hard drive (D) (arrives in 2-4 days) to possibly recovered data,
    on a neutral, unused disk.
DEUTSCH:
Hallo,
ich brauche eure Hilfe. Ich habe kein Zugriff mehr auf meine Daten, die nach einem Festplattenausfall nicht mehr erreichbar waren.
Allgemeine Infos:
  • NAS-System: WD My Cloud EX2 Ultra (gekauft 2019)
  • Raid 1 (Beide 1zu1 gespiegelt)
  • ca. 4,5 TB Genutzt
  • 2 Benutzer
  • 1 Geteiltes Laufwerk / Freigabe
  • Jeweils 1 Privates Laufwerk / Freigabe
Geschichte:
  1. Eine LED hat rot geleuchtet
  2. Festplatte (A) war fehlerhaft - In DiskDrill steht ~2000 fehlerhafte Sektoren
  3. Die freigaben waren verschwunden
  4. Ich habe versucht die Freigaben wieder hinzuzufügen
  5. Ticket Kontakt mit WD
    5.1. Empfehlung einer neuen Festplatte
  6. Neue “Festplatte C” (WD RED 6 TB) gekauft und eingebaut
  7. Raid wurde wiederhersgestellt und alles war gut
  8. Kurz darauf waren beide LEDs rot und ich konnte auf nichts mehr zugreifen (verstehe nicht warum)
  9. Festplatte B und C waren also nicht mehr erreichbar
  10. Raid neu aufgebaut Festplatten (B und C) mussten dabei formatiert werden
  11. Kontakt mit WD-Support leider ohne erfolg.
    11.1. Datenrettung oder Pech gehabt :frowning:
Meine aktuellen Versuche:
  • Festplatte A (die als defekt galt) an PC angeschloss
  • Mit DiskDrill (gekauft) ausgelesen, nach 16 Stunden ~1 Million Daten (2,8TB) gefunden
    • Leider nicht der Originale Dateiname
    • Leider nicht der originale Pfad, um die Daten zuordnen zu können
  • Mit Stellaris Data Recovery (gekauft) ausgelesen, nach 16 Stunden ~70k Daten (1 TB) gefunden
  • Mit Recuva (Testversion) keinen wirklichen Erfolg gehabt
  • MIt dmde (gekauft) keinen wirklichen Erfolg gehabt
Was kann ich tun um die Daten wiederzubekommen?
  • Am besten mit dem Original-Dateinamen und dem Original-Dateipfad
Meine Ideen:
  • Mit Linux auf die Daten zugfreifen? Leider scheitert es an der VirtualBox
    • Geht das ohne Recover-Tool?
    • Mit einem Linux-Recover-Tool
  • Mit anderen Recover-Tools die Datenrettung probieren
  • Zu Datenretter-Profis gehen (je nach kosten)
  • Die Daten mühevoll umbenennen, sortieren und stück für stück per Hand auslesen. Ist leider bei 4,5 TB sehr mühsam ohne Dateinamen und Pfad und tausenden Temp-Daten
  • die aktuell verbauten Festplatten (B und C) ausbauen und ebenfalls mit einem Recover-Tool auslesen
    • Also aus 3(A, B und C) mach 1 (D(Fabrikneue))
Zusatzinfo:
  • Ich habe eine vierte Festplatte (D) gekauft (kommt in 2-4 Tagen an), um evtl. wiederhergestellt Daten,
    auf eine neutrale, unbenutzte Platte schieben zu können.
Hi @ihurbie,
