I have (4) WD WD20 EARS 2TB hard drives that are not meshing well in a RAID configuration and needed to be able to see if the drives have the same firmware version. Is there a way to view this info in the Mac OS? Thanks
lets see if it helps
Thanks but since the drives are connected by either USB or Firewire it will not show SMART status. Is there another way? Thanks again.
