I purchased 2 RE4 drives (WD5003ABYX) for backup drives but didn’t realize that they weren’t intended to be used as single drives. As a single drive, they’re supposedly more likely to lose data if there is an error because the drive uses TLER.
What is the risk?
Will there be just a few lost files or will there be a total loss of data on the drive?
Hi there, as long as the drive itself is taken care of and you’re monitoring its performance (degradation, bad sectors, temperature) then it should not matter until it dies.
