Mestre
October 6, 2011, 10:06pm
1
I was yesterday watching a AVI with mpeg audio over the network and all of the suden i lost audio. he came back for a few seconds and gone again. tested another AVI with mpeg audio and the same thing. so i decided to upgrade the firmware from 2.05 to 2.07. it took a long time but done. tested again and now the AVI with mepg audio is with slow motion video and no audio, or better it plays audio for 1 second and gone. teste witn a MKV file with digital audio and no problem at all.
now i just upgrade to the 2.8 firmware, but sttil same isue.
anyone knows a solucion for this ?
apreciated.
Please post the full TEXT output of MEDIAINFO for such a file.
http://mediainfo.sourceforge.net
Mestre
October 6, 2011, 10:37pm
3
General
Complete name : G:\TV SERIES\Fringe\S3\fringe.319.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 349 MiB
Duration : 43mn 47s
Overall bit rate mode : Variable
Overall bit rate : 1 116 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 43mn 47s
Bit rate : 974 Kbps
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.185
Stream size : 305 MiB (87%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 43mn 47s
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 40.3 MiB (12%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 205 ms
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
Mestre
October 7, 2011, 1:58am
4
I just call WD about this, and they will send me a new hub in a few days. Problems seams hardware related, since firmware upgrade didn’t help at all.
