Hello
When creating files in my Home Duo, these are created with the last access date of June 7, 1906. This causes problems in my backup program that uses the timestamp to decide if the file is the same as it already has or needs to be updated.
Any solution to this problem? It is always that I create or copy a file, from windows 8 or from android. Always imputes the date of last access to June 7, 1906 …
Thank you
